Datasheet Texas Instruments UCC37324DRG4 — Даташит
| Серия | UCC37324 |
| Модель | UCC37324DRG4 |
Двойные высокоскоростные драйверы MOSFET с пиковым током 4 А, 8-SOIC, от 0 до 70
UCCx732x Dual 4-A Peak High-Speed Low-Side Power-MOSFET Drivers datasheet
PDF, 1.3 Мб, Версия: I, Файл опубликован: 29 июл 2016
Купить UCC37324DRG4 на РадиоЛоцман.Цены — от 56 до 76 ₽9 предложений от 9 поставщиков Драйвер FET, Driver 4.5A 2Out Lo Side Non-Inv 8Pin SOIC T/R | |||
| UCC37324DRG4 Texas Instruments | 56 ₽ | ||
| UCC37324DRG4 | по запросу | ||
| UCC37324DRG4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | 37324 |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Channel Input Logic | Non-Inverting |
| Fall Time | 15 нс |
| Input Threshold | CMOS,TTL |
| Input VCC(Max) | 15 В |
| Input VCC(Min) | 4.5 В |
| Количество каналов | 2 |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | SOIC |
| Peak Output Current | 4 A |
| Power Switch | MOSFET,IGBT,GaNFET |
| Prop Delay | 25 нс |
| Rating | Catalog |
| Rise Time | 20 нс |
| Special Features | Dual Non-inverting Outputs,Hysteretic Logic |
- Evaluation Modules & Boards: UCC3895EVM-001
UCC3895 Evaluation Module
- Synchronous Rectifiers of a Current DoublerPDF, 207 Кб, Файл опубликован: 27 фев 2003
Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary
Серия: UCC37324 (8)
- UCC37324D UCC37324DG4 UCC37324DGN UCC37324DGNR UCC37324DR UCC37324DRG4 UCC37324P UCC37324PE4
- Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
