Datasheet Texas Instruments OPA551FA/500 — Даташит
СерияOPA551
МодельOPA551FA/500
Высоковольтные сильноточные операционные усилители 7-DDPAK/TO-263 от -40 до 125
OPA55x High-Voltage, High-Current Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 7 янв 2016
Pin7
Package TypeKTW
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Package QTY500
МаркировкаOPA551FA
Width (мм)8.89
Length (мм)10.1
Thickness (мм)4.44
Max Height (мм)4.65
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)92 дБ
CMRR(Typ)102 дБ
GBW(Typ)3 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)8.5 мА
Iq per channel(Typ)7 мА
Количество каналов1
Offset Drift(Typ)7 uV/C
Output Current(Typ)380 мА
Package GroupDDPAK/TO-263
Package Size: mm2:W x L7DDPAK/TO-263: 154 mm2: 15.24 x 10.1(DDPAK/TO-263) PKG
Rail-to-RailNo
Slew Rate(Typ)15 V/us
Total Supply Voltage(Max)60 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA551FA/500
