Datasheet Texas Instruments SN74LVTH16241DGGR — Даташит
СерияSN74LVTH16241
МодельSN74LVTH16241DGGR
16-битные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями 48-TSSOP от -40 до 85
3.3-V ABT 16-Bit Buffers/Drivers With 3-State Outputs datasheet
PDF, 723 Кб, Версия: D, Файл опубликован: 1 ноя 2006
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVTH16241
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)0.005 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.5 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH16241 (2)
На английском языке: Datasheet Texas Instruments SN74LVTH16241DGGR
