Datasheet ТI THS3095DDAG4 — Даташит
СерияTHS3095
МодельTHS3095DDAG4
Datasheet Texas Instruments THS3095DDAG4
Одиночный высоковольтный операционный усилитель с низкими искажениями и токовой обратной связью с 8-SO PowerPAD с отключением питания от -40 до 85
THS309x High-voltage, Low-distortion, Current-feedback Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 31 дек 2015
  • Design of Differential Filters for High-Speed Signal Chains (Rev. B)
    PDF, 166 Кб, Версия: B, Файл опубликован: 30 апр 2010
    Differential filters have many desirable attributes. The task of designing differential filters can seem daunting at first. Single-ended filters designed in any filter design package can be converted to a differential implementation. This application report explores simple conversion techniques for low-pass, high-pass, and band-pass LC filters.
  • Interfacing op amps to high-speed DACs, Part 1: Current-sinking DACs
    PDF, 319 Кб, Файл опубликован: 14 июл 2009
  • Interfacing op amps to high-speed DACs, Part 2: Current-sourcing DACs
    PDF, 617 Кб, Файл опубликован: 4 окт 2009
  • Design for a Wideband Differential Transimpedance DAC Output (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
    High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • Voltage Feedback vs. Current Feedback Op Amps
    PDF, 93 Кб, Файл опубликован: 30 ноя 1998
    This application report contrasts and compares the characteristics and capabilities of voltage and current feedback operational amplifiers. The report also points out the many similarities between the two versions.
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Q4 2009 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 4 окт 2009
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
Серия: THS3095 (5)
На английском языке: Datasheet Texas Instruments THS3095DDAG4
Политика конфиденциальности
