Datasheet Texas Instruments TPS61096DSSR — Даташит
| Серия | TPS61096 |
| Модель | TPS61096DSSR |
28-V Output Voltage Boost Converter with 1-ВµA Quiescent Current 12-WSON -40 to 85
Купить TPS61096DSSR на РадиоЛоцман.Цены — от 72 до 207 ₽9 предложений от 9 поставщиков IC REG BOOST ADJ 350MA 12WSON. Boost Switching Regulator IC Positive Adjustable 4.5V 1 Output 350mA (Switch) 12-WFDFN Exposed Pad. PMIC... | |||
| TPS61096DSSR Texas Instruments | 207 ₽ | ||
| TPS61096DSSR Texas Instruments | по запросу | ||
| Pin | 12 |
| Package Type | DSS |
| Industry STD Term | WSON |
| JEDEC Code | R-PDSO-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | S61096 |
| Width (мм) | 3 |
| Length (мм) | 2 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Approx. Price (US$) | 0.80 | 1ku |
| Duty Cycle(Max)(%) | 90 |
| Iq(Typ)(mA) | 0.001 |
| Operating Temperature Range(C) | -40 to 85 |
| Package Group | WSON |
| Rating | Catalog |
| Regulated Outputs(#) | 1 |
| Special Features | Adjustable Current Limit Enable Light Load Efficiency |
| Switch Current Limit(Min)(A) | 0.4 |
| Switch Current Limit(Typ)(A) | 0.5 |
| Тип | Converter |
| Vin(Max)(V) | 5.5 |
| Vin(Min)(V) | 1.8 |
| Vout(Max)(V) | 28 |
| Vout(Min)(V) | 4.5 |
| Бессвинцовая технология (Pb Free) | Да |
- Evaluation Modules & Boards: TPS61096EVM-787
Evaluation Board for TPS61096 28-V Output Voltage Boost Converter with Ultra-Low Quiescent Current
- AN-1112 DSBGA Wafer Level Chip Scale Package (Rev. AG)PDF, 13.7 Мб, Версия: AG, Файл опубликован: 12 авг 2015
- Automated Frequency Response AnalyzerPDF, 939 Кб, Файл опубликован: 9 окт 2013
This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments. - Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Design considerations for a resistive feedback divider in a DC/DC converterPDF, 393 Кб, Файл опубликован: 26 апр 2012
- Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed. - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61096 (2)
- TPS61096DSSR TPS61096DSST
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
