Datasheet Texas Instruments SN74LVC04APW — Даташит
| Серия | SN74LVC04A |
| Модель | SN74LVC04APW |
Шестигранный инвертор 14-TSSOP от -40 до 125
SNx4LVC04A Hex Inverters datasheet
PDF, 1.4 Мб, Версия: T, Файл опубликован: 12 дек 2016
Купить SN74LVC04APW на РадиоЛоцман.Цены — от 7.33 до 89 ₽53 предложений от 23 поставщиков Микросхема Логический чип, TEXAS INSTRUMENTS SN74LVC04APWE4 Inverter, 74LVC04, 1Input, 24mA, 1.65V to 3.6V, TSSOP-14 | |||
| SN74LVC04APWE4 Texas Instruments | 53 ₽ | ||
| SN74LVC04APW Texas Instruments | по запросу | ||
| SN74LVC04APWE4 Texas Instruments | по запросу | ||
| Pin | 14 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 90 |
| Carrier | TUBE |
| Маркировка | LC04A |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 6 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 8,7.5,5.5,4.5 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74LVC04A (29)
- SN74LVC04AD SN74LVC04ADBLE SN74LVC04ADBR SN74LVC04ADBRG4 SN74LVC04ADE4 SN74LVC04ADG4 SN74LVC04ADGVR SN74LVC04ADGVRE4 SN74LVC04ADGVRG4 SN74LVC04ADR SN74LVC04ADRE4 SN74LVC04ADRG3 SN74LVC04ADRG4 SN74LVC04ADT SN74LVC04ANSR SN74LVC04ANSRG4 SN74LVC04APW SN74LVC04APWE4 SN74LVC04APWG4 SN74LVC04APWLE SN74LVC04APWR SN74LVC04APWRE4 SN74LVC04APWRG3 SN74LVC04APWRG4 SN74LVC04APWT SN74LVC04APWTE4 SN74LVC04APWTG4 SN74LVC04ARGYR SN74LVC04ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
