Datasheet Texas Instruments LM74CIMX-5 — Даташит
СерияLM74
МодельLM74CIMX-5
В±1.25В°C Temperature Sensor with SPI Interface 8-SOIC -55 to 150
LM74 SPI/ MICROWIRE 12-Bit Plus Sign Temperature Sensor datasheet
PDF, 1.2 Мб, Версия: K, Файл опубликован: 22 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаLM74CIM5
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLM74CIMX-5/NOPB
Replacement CodeS
AddressesNA
Approx. Price (US$)0.65 | 1ku
InterfaceSPI
Microwire
Iq(Typ)(uA)265
Local Sensor Accuracy(Max)(+/- C)1.25
Operating Temperature Range(C)-40 to 125
-55 to 150
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Special FeaturesShutdown
Supply Current(Max)(uA)470
Supply Current(Typ)(uA)265
Supply Voltage(Max)(V)5.5
Supply Voltage(Min)(V)2.65
3
Temp Resolution(Max)(bits)13
RoHSTBD
  • Sensing and Monitoring for Control and Protection Seminar
    PDF, 245 Кб, Файл опубликован: 17 фев 2003
  • Tiny Temperature Sensors for Remote Systems
    PDF, 156 Кб, Файл опубликован: 17 фев 2003
  • AN-1256 Tiny Temperature Sensors for Portable Systems (Rev. A)
    PDF, 77 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The last year has seen the introduction of silicon temperature sensors in revolutionary small packages,ideal for portable systems. This application report discusses trade-offs in accuracy, as well as how tochoose between thermistors and analog output IC temperature sensors.
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
LM74CIMX5, LM74CIMX 5
На английском языке: Datasheet Texas Instruments LM74CIMX-5
