Datasheet ТI 8500401FA — Даташит
СерияSN54HC4040
Модель8500401FA
Datasheet Texas Instruments 8500401FA
Асинхронные 12-битные двоичные счетчики 16-CFP от -55 до 125
SN54HC4040, SN74HC4040 datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 15 сен 2003
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments 8500401FA
Политика конфиденциальности
