Datasheet Texas Instruments THS4271DRBT — Даташит
СерияTHS4271
МодельTHS4271DRBT
Сверхбыстрый высокоскоростной усилитель со сверхнизкими искажениями 8-SON от -40 до 85
Low Noise, High Slew Rate, Unity Gain Stable Voltage Feedback Amplifier datasheet
PDF, 1.7 Мб, Версия: F, Файл опубликован: 16 окт 2009
Package TypeDRB
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Маркировка4271
Width (мм)3
Length (мм)3
Thickness (мм).88
Max Height (мм)1
2nd Harmonic65 dBc
3rd Harmonic80 dBc
@ MHz30
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl1400 МГц
CMRR(Min)67 дБ
CMRR(Typ)72 дБ
GBW(Typ)1400 МГц
Input Bias Current(Max)15000000 pA
Iq per channel(Max)24 мА
Iq per channel(Typ)22 мА
Количество каналов1
Offset Drift(Typ)10 uV/C
Output Current(Typ)160 мА
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Rail-to-RailNo
Slew Rate(Typ)1000 V/us
Total Supply Voltage(Max)10 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)3 нВ/rtГц
Vn at Flatband(Typ)3 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Evaluation Modules & Boards: THS4271EVM
    THS4271 Evaluation Module
  • Evaluation Modules & Boards: THS4271EVM-UG
    THS4271 Evaluation Module with Unity Gain
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS4271DRBT
