Datasheet Texas Instruments CD54HC161F — Даташит
СерияCD54HC161
МодельCD54HC161F
Высокоскоростной 4-битный двоичный счетчик КМОП-логики с асинхронным сбросом 16-CDIP от -55 до 125
CD54/74HC161, CD54/74HCT161, CD54/74HC163, CD54/74HCT163 datasheet
PDF, 469 Кб, Версия: D, Файл опубликован: 13 окт 2003
16 предложений от 16 поставщиков
, Binary Counter, HC/UH Series, Synchronous, Positive Edge Triggered, 4-Bit, Up Direction, CMOS, CDIP16,
CD54HC161F
Harris
306 ₽
CD54HC161F
817 ₽
Элитан
CD54HC161F
3 223 ₽
Hi-Tech Circuit Group
CD54HC161F
Harris
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаCD54HC161F
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Bits4
F @ Nom Voltage(Max)28 Mhz
FunctionCounter
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
ТипBinary
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)39 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC161 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC161F
