Datasheet Texas Instruments TL022CPSR — Даташит
СерияTL022
МодельTL022CPSR
Двойной маломощный операционный усилитель общего назначения 8-SO от 0 до 70
Dual Low-Power Operational Amplifiers datasheet
PDF, 680 Кб, Файл опубликован: 1 сен 1990
Package TypePS
Industry STD TermSOP
Package QTY2000
МаркировкаT022
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)60 дБ
CMRR(Typ)72 дБ
GBW(Typ)0.5 МГц
Input Bias Current(Max)100000 pA
Iq per channel(Max)0.125 мА
Iq per channel(Typ)0.065 мА
Количество каналов2
Output Current(Typ)6 мА
Package GroupSO
Package Size: mm2:W x L8SO: 48 mm2: 7.8 x 6.2(SO) PKG
Rail-to-RailNo
Slew Rate(Typ)0.5 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)50 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
На английском языке: Datasheet Texas Instruments TL022CPSR
