Datasheet Texas Instruments UC3706DWTRG4 — Даташит
СерияUC3706
МодельUC3706DWTRG4
Двойные высокоскоростные драйверы MOSFET 16-SOIC от 0 до 70
Dual Output Driver datasheet
PDF, 750 Кб, Версия: A, Файл опубликован: 2 май 2001
IC DUAL OUTPUT DRIVER 16-SOIC / Driver 1.5A 2-OUT High Speed Inv/Non-Inv 16-Pin SOIC T/R
UC3706DWTRG4
278 ₽
UC3706DWTRG4
507 ₽
UC3706DWTRG4
UC3706DWTRG4
Pin16
Package TypeDW
Package QTY2000
МаркировкаUC3706DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC3706 (6)
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
На английском языке: Datasheet Texas Instruments UC3706DWTRG4
