Datasheet Texas Instruments TPS54623RHLR — Даташит
СерияTPS54623
МодельTPS54623RHLR
Входное напряжение от 4,5 до 17 В, ток 6 А, синхронный понижающий преобразователь SWIFT с эффективностью при небольшой нагрузке 14-VQFN от -40 до 150
TPS54623 4.5-V to 17-V Input, 6-A Synchronous Step Down SWIFTв„ў Converter With Light Load Efficiency and Hiccup Over Current Protection datasheet
PDF, 1.9 Мб, Версия: B, Файл опубликован: 28 дек 2016
Pin14
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка54623
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)6 A
Iq(Typ)0.25 мА
Рабочий диапазон температурот -40 до 150 C
Package GroupVQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking
Switching Frequency(Max)1600 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)17 В
Vin(Min)4.5 В
Vout(Max)15 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS54623EVM-012
    Evaluation Module for TPS54623 Synchronous Step-Down SWIFT Converter
  • Calculating Efficiency
    PDF, 175 Кб, Файл опубликован: 19 фев 2010
    This application report provides a step-by-step procedure for calculating buck converter efficiency and power dissipation at operating points not provided by the data sheet.
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54623 (2)
На английском языке: Datasheet Texas Instruments TPS54623RHLR
