Datasheet Texas Instruments OPA365AIDBVR — Даташит
СерияOPA365
МодельOPA365AIDBVR
Малошумящий операционный усилитель Rail-to-Rail с одинарным питанием, 2,2 В, 50 МГц, 5-SOT-23 от -40 до 125
OPAx365 50-MHz, ZerГё-Crossover, Low-Distortion, High CMRR, RRI/O, Single-Supply Operational Amplifier datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 25 авг 2016
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаOAVQ
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
2nd Harmonic81 dBc
3rd Harmonic93 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesZero Crossover
АрхитектураCMOS,Voltage FB
BW @ Acl50 МГц
CMRR(Min)100 дБ
CMRR(Typ)120 дБ
GBW(Typ)50 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)5 мА
Iq per channel(Typ)4.6 мА
Количество каналов1
Offset Drift(Typ)1 uV/C
Output Current(Typ)65 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)25 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)2.2 +5V=5, +/-5V=10
Vn at 1kHz(Typ)4.5 нВ/rtГц
Vn at Flatband(Typ)4.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.2 мВ
  • Evaluation Modules & Boards: ADS7049-Q1EVM-PDK
    ADS7049-Q1 Ultra-Low-Power Ultra-Small-Size 12-Bit 2MSPS SAR ADC Performance Demonstration Kit (PDK)
  • Zero-crossover Amplifiers: Features and Benefits (Rev. A)
    PDF, 296 Кб, Версия: A, Файл опубликован: 9 фев 2017
  • Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319
    PDF, 1.5 Мб, Файл опубликован: 24 июн 2009
    The one size fits all approach to operational amplifiers is not effective. Every application has its own specific requirements that must be fulfilled. Appropriate selection of the op amp that drives an analog-to-digital converter (ADC) in a low-power application is a critical step. Most available low-power op amps trade off low-power features with other parameters such as bandwidth, settling t
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA365AIDBVR
