Datasheet Texas Instruments CD74ACT540MG4 — Даташит
| Серия | CD74ACT540 |
| Модель | CD74ACT540MG4 |
Восьмеричные инвертирующие буферы/драйверы линий с выходами с 3 состояниями 20-SOIC от -55 до 125
Octal Buffer/Line Drivers, 3-State datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 16 ноя 1999
Купить CD74ACT540MG4 на РадиоЛоцман.Цены — от 23 до 57 ₽8 предложений от 8 поставщиков IC BUFFER INVERT 5.5V 20SOIC. Buffer, Inverting 1 Element 8 Bit per Element 3-State Output 20-SOIC. Logic - Buffers, Drivers, Receivers,... | |||
| CD74ACT540MG4 Texas Instruments | 53 ₽ | ||
| CD74ACT540MG4 Texas Instruments | 57 ₽ | ||
| CD74ACT540MG4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | ACT540M |
| Width (мм) | 7.5 |
| Length (мм) | 12.8 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 90 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ACT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 6.5 нс |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT540 (6)
- CD74ACT540E CD74ACT540EE4 CD74ACT540M CD74ACT540M96 CD74ACT540M96G4 CD74ACT540MG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
