Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM25574MT/NOPB — Даташит
СерияLM25574
МодельLM25574MT/NOPB
Понижающий импульсный регулятор 42 В, 0,5 А 16-TSSOP от -40 до 125
LM25574 42-V, 0.5-A Step-Down Switching Regulator datasheet
PDF, 996 Кб, Версия: H, Файл опубликован: 23 авг 2017
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаL25574MT
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)95 %
Iout(Max)0.5 A
Iq(Typ)1 мА
Package GroupTSSOP
Regulated Outputs1
Special FeaturesFrequency Synchronization
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)6 В
Vout(Max)40 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: LM25574EVAL
    Evaluation Board for LM25574, 42V, 0.5A Step-Down Switching Regulator
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Quick Start Guide for a 0.5 Amp Buck Regulator Using The LM5574 and LM25574 (Rev. B)
    PDF, 61 Кб, Версия: B, Файл опубликован: 23 апр 2013
    The LM5574 and LM25574 switching regulators feature all of the functions necessary to implement anefficient high voltage buck regulator using a minimum of external components. These easy to useregulators include either a 42V (LM25574) or a 75V (LM5574) N-Channel buck switch with an outputcurrent capability of 0.5 Amps. The operating frequency is programmable from 50kHz up to 1MHz.Protectio
  • Overcoming Challenges in Designing Step-Dwn Reg Apps w/40V Input Voltage
    PDF, 538 Кб, Файл опубликован: 30 мар 2007
Серия: LM25574 (3)
На английском языке: Datasheet Texas Instruments LM25574MT/NOPB
