Datasheet Texas Instruments OPA2652U/2K5 — Даташит
СерияOPA2652
МодельOPA2652U/2K5
SpeedPlus™ Dual, 700 МГц, операционный усилитель с обратной связью по напряжению, 8-SOIC, от -40 до 85
SpeedPlusв„ў Dual, 700MHz, Voltage-Feedback Operational Amplifier datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 25 май 2006
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаOPA2652U
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
2nd Harmonic78 dBc
3rd Harmonic72 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl700 МГц
CMRR(Min)75 дБ
CMRR(Typ)95 дБ
GBW(Typ)700 МГц
Input Bias Current(Max)15000000 pA
Iq per channel(Max)6.6 мА
Iq per channel(Typ)5.5 мА
Количество каналов2
Offset Drift(Typ)7 uV/C
Output Current(Typ)140 мА
Rail-to-RailNo
Slew Rate(Typ)335 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vn at Flatband(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)7 мВ
  • Evaluation Modules & Boards: DEM-OPA-SOT-2A
    DEM-OPA-SOT-2A
  • Evaluation Modules & Boards: DEM-OPA268XU
    DEM-OPA268xU: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA-SO-2A
    DEM-OPA-SO-2A
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2652U/2K5
