Datasheet Texas Instruments TPS79919YZUR — Даташит
СерияTPS799
МодельTPS79919YZUR
Линейный стабилизатор 5-DSBGA, 200 мА, с низким током покоя, сверхнизким уровнем шума, высоким PSRR и низким падением напряжения, от -40 до 125
TPS799 200-mA, Low-Quiescent Current, Ultralow Noise, High-PSRR Low-Dropout Linear Regulator datasheet
PDF, 1.3 Мб, Версия: K, Файл опубликован: 5 янв 2011
Pin5
Package TypeYZU
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаF6
Width (мм)1.616
Length (мм)1.25
Pitch (мм).5
Max Height (мм).625
Accuracy(%)2
Additional FeaturesEnable
Fast Transient Response
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)0.28 | 1ku
Fixed Output Options(V)1.2
1.25
1.3
1.5
1.8
1.85
1.9
1.95
2
2.1
2.5
2.6
2.7
2.75
2.8
2.85
3
3.15
3.2
3.3
4.2
4.5
Iout(Max)(A)0.2
Iq(Typ)(mA)0.04
Noise(uVrms)29
Operating Temperature Range(C)-40 to 125
Output Capacitor TypeCeramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)38
Package GroupDSBGA
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Regulated Outputs(#)1
Vdo(Typ)(mV)100
Vin(Max)(V)6.5
Vin(Min)(V)2.7
Vout(Max)(V)6.5
Vout(Min)(V)1.2
  • Evaluation Modules & Boards: TPS799XXEVM-105
    TPS799xx Evaluation Module
  • Understanding LDO Dropout
    PDF, 52 Кб, Файл опубликован: 9 май 2005
    Not all low dropout (LDO) linear regulator data sheets provide the voltage dropout information needed for all applications. This application report shows a designer how to use an LDO data sheet's specified dropout performance to determine the dropout voltage at other operating conditions.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TPS79919YZUR
