Datasheet Texas Instruments LMT70AYFQT — Даташит
| Серия | LMT70A |
| Модель | LMT70AYFQT |
В±0.1В°C Matching Accuracy Precision Analog Temperature Sensor 4-DSBGA -55 to 150
LMT70, LMT70A В±0.05В°C Precision Analog Temperature Sensor, RTD and Precision NTC Thermistor IC datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 11 май 2015
Купить LMT70AYFQT на РадиоЛоцман.Цены — от 38 до 717 ₽34 предложений от 15 поставщиков SENSOR ANALOG -55C-150C 4DSBGA. Temperature Sensor Analog, Local -55°C ~ 150°C 5.194mV/°C 4-DSBGA (0.81x0.81). Temperature Sensors - Analog and Digital Output... | |||
| LMT70AYFQT Texas Instruments | от 114 ₽ | ||
| LMT70AYFQT Texas Instruments | 717 ₽ | ||
| LMT70AYFQT Texas Instruments | по запросу | ||
| Pin | 4 |
| Package Type | YFQ |
| Industry STD Term | DSBGA |
| JEDEC Code | S-XBGA-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Thickness (мм) | .42 |
| Pitch (мм) | .4 |
| Max Height (мм) | .675 |
| Mechanical Data | Скачать |
| Interface | Analog Output |
| Local Sensor Accuracy(Max) | 0.36 +/- C |
| Рабочий диапазон температур | от -55 до 150 C |
| Output Impedance | 80 Ohm |
| Package Group | DSBGA |
| Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
| Rating | Catalog |
| Sensor Gain | -5.19 mV/Deg C |
| Supply Current(Max) | 12 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 2 В |
- Evaluation Modules & Boards: LMT70EVM
LMT70 Evaluation Module Precise Analog Output Temperature Sensor with Output Enable
- SC Temp Sensors Challenge Precision RTDs and Thermistors in Build AutomationPDF, 247 Кб, Файл опубликован: 21 апр 2015
Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT70A (2)
- LMT70AYFQR LMT70AYFQT
- Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
