Datasheet Texas Instruments SN65HVD20DRG4 — Даташит
СерияSN65HVD20
МодельSN65HVD20DRG4
Расширенный синфазный трансивер RS-485 8-SOIC от -40 до 85
SN65HVD2x Extended Common-Mode RS-485 Transceivers datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 18 ноя 2016
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Approx. Price (US$)1.40 | 1ku
Common Mode Range-20 to 25
DuplexHalf
Fail SafeIdle
Open
Short
Fault Protection(V)-27 to 27
HBM ESD(kV)16
ICC(Max)(mA)9
IEC 61000-4-2 Contact(+/- kV)N/A
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes64
Operating Temperature Range(C)-40 to 85
Signaling Rate(Max)(Mbps)25
Supply Voltage(s)(Nom)(V)5
RoHSНе совместим
  • Evaluation Modules & Boards: SN65HVD22EVM
    SN65HVD22EVM Evaluation Module
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
  • Semiconductors > Interface > RS-485 Transceivers
На английском языке: Datasheet Texas Instruments SN65HVD20DRG4
