Datasheet ТI UC2965DTR — Даташит
| Серия | UC2965 |
| Модель | UC2965DTR |
Прецизионный эталон с усилителем с малой погрешностью смещения 8-SOIC от -40 до 85
- U-160 Simple Circuit Modifications Enhance Optocoupler PerformancePDF, 240 Кб, Файл опубликован: 5 сен 1999
The optocoupler is often used in pulse-width-modulated power converters to transmit an error signal across an isolation boundary. This error signal is used on the primary side to close the control loop. This application note describes a typical optocoupler feedback scheme using the UC3965 Precision Reference with Low-Offset Error Amplifier and a Siemens Optoelectronics IL207 optocoupler. The discu - U-165 Design Rvw: Isolated 50 W Flyback Converter Using UCC3809 and UC3965PDF, 266 Кб, Файл опубликован: 5 сен 1999
The flyback power stage is a popular choice for single and multiple output DC-to-DC converters at power levels of 150W or less. Without the output inductor required in buck-derived topologies, such as the forward or push-pull converter, the component count and cost are reduced. This application note will re-view the design procedure for the power stage and control electronics of a flyback converte
Серия: UC2965 (2)
- UC2965D UC2965DTR
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Feedback Signal Generator
