Datasheet Texas Instruments TPS79301DBVR — Даташит
СерияTPS793
МодельTPS79301DBVR
Высокий PSRR, низкий уровень шума, LDO с одним выходом, 200 мА, 6-SOT-23 от -40 до 125
TPS793 Low-Noise, High PSRR, RF, 200-mA Low-Dropout Linear Regulators in NanoStarв„ў Wafer Chip Scale and SOT-23 datasheet
PDF, 1.2 Мб, Версия: L, Файл опубликован: 7 авг 2014
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаPGVI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Точность2 %
Fixed Output Options1.8,2.5,2.8,2.85,3,3.3,4.75 В
Iout(Max)0.2 A
Iq(Typ)0.17 мА
Noise32 uVrms
Output Capacitor TypeCeramic
PSRR @ 100KHz44 дБ
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Regulated Outputs1
Special FeaturesEnable
Thermal Resistance ОёJA178 В°C/W
Vdo(Typ)112 мВ
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)5.4 В
Vout(Min)1.22 В
  • Evaluation Modules & Boards: TMDXEVM368
    TMS320DM36x Evaluation Module
  • Evaluation Modules & Boards: TPS793285YEQEVM
    TPS793285Y Evaluation Module
  • Evaluation Modules & Boards: TPS79325YEQEVM
    Evaluation Module for TPS79325 chipscale LDO
  • Evaluation Modules & Boards: TPS79330YEQEVM
    Evaluation Module for TPS79330 chipscale LDO
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible With Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Package
  • NanoStarв„ў Wafer Chip-Scale Package Design Guide
    PDF, 286 Кб, Файл опубликован: 5 сен 2003
    To satisfy market demand for an ultra-small, staggered 5-ball wafer-level chip-scale package, TI has introduced the 170Ојm NanoStar YEQ package. Since staggered ball WCSPs are not registered under the JEDEC MO-211 standard, there are no formal industry-standard guidelines on proper use of devices in this package. This application note gives guidelines for reliable, high-performance use of the YE
  • NanoStarв„ў & NanoFreeв„ў 300Ојm Solder Bump WCSP Application
    PDF, 749 Кб, Файл опубликован: 2 фев 2004
    The NanoStarв„ў Wafer Chip-Scale Package (WCSP) is a family of bare die packages developed for applications that require the smallest possible package. WCSP provides electrical interconnection via solder spheres attached to the die and is aligned with JEDEC package standard MOв€’211. NanoStarв„ў, with advanced materials engineering technology, has demonstrated excellent board level rel
  • Cycloneв„ў III FPGA Starter Kit Power Reference Design
    PDF, 314 Кб, Файл опубликован: 27 мар 2008
    This power supply was designed to power the 3C25F324 starter kit. This reference design has many benefits over the existing power supply found on the starter kit demonstration board.
На английском языке: Datasheet Texas Instruments TPS79301DBVR
