Datasheet Texas Instruments DAC124S085CISDX/NOPB — Даташит
СерияDAC124S085
МодельDAC124S085CISDX/NOPB
12-битный цифро-аналоговый преобразователь Micro Power QUAD с выходом Rail-to-Rail 10-WSON от -40 до 105
DAC124S085 12-Bit Micro Power Quad Digital-to-Analog Converter With Rail-to-Rail Output datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 26 апр 2016
Pin10
Package TypeDSC
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY4500
МаркировкаX67C
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Approx. Price (US$)3.00 | 1ku
Code to Code Glitch(Typ)(nV-sec)12
DAC ArchitectureString
DAC Channels4
Gain Error(Max)(%FSR)1
INL(Max)(+/-LSB)8
InterfaceSPI
Operating Temperature Range(C)-40 to 105
Output Range Max.(mA/V)5.5
Тип выходаBuffered Voltage
Package GroupWSON
Package Size: mm2:W x L (PKG)See datasheet (WSON)
Power Consumption(Typ)(mW)1.1
Reference: TypeExt
Resolution(Bits)12
Sample / Update Rate(MSPS)2.5
Settling Time(Вµs)8.5
Special FeaturesN/A
Zero Code Error(Typ)(mV)15
  • Evaluation Modules & Boards: DAC124S085EVM
    12-bit 4 Channel Digital to Analog Converter Evaluation Module
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
На английском языке: Datasheet Texas Instruments DAC124S085CISDX/NOPB
