Datasheet Texas Instruments 74CBT1G125DCKRG4 — Даташит
СерияSN74CBT1G125
Модель74CBT1G125DCKRG4
Одиночный переключатель шины FET 5-SC70 от -40 до 85
SN74CBT1G125 datasheet
PDF, 809 Кб, Версия: G, Файл опубликован: 13 янв 2003
Pin5555
Package TypeDCKDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY3000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаSM3SMTSMUSMS
Width (мм)1.251.251.251.25
Length (мм)2222
Thickness (мм).9.9.9.9
Pitch (мм).65.65.65.65
Max Height (мм)1.11.11.11.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)200 Mhz
Gate TypeBUS SWITCH
ICC @ Nom Voltage(Max)0.001 мА
LogicTrue
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesSPST switch,low tpd,unbuffered,low Ron,3-state
Sub-FamilyAnalog Switch
Technology FamilyCBT
VCC(Max)5.5 В
VCC(Min)4 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)0.25 нс
  • Evaluation Modules & Boards: DP159RGZEVM
    DP159RGZEVM Evaluation Module
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments 74CBT1G125DCKRG4
