Datasheet Texas Instruments SN74AS869NT3 — Даташит
СерияSN74AS869
МодельSN74AS869NT3
Синхронные 8-битные реверсивные счетчики 24-PDIP от 0 до 70
Synchronous 8-Bit Up/Down Counters datasheet
PDF, 367 Кб, Версия: C, Файл опубликован: 1 янв 1995
Pin24
Package TypeNT
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.73
Length (мм)31.64
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Approx. Price (US$)5.35 | 1ku
Bits(#)8
F @ Nom Voltage(Max)(Mhz)125
FunctionCounter
ICC @ Nom Voltage(Max)(mA)195
Тип входаTTL
Output Drive (IOL/IOH)(Max)(mA)20/-2
Тип выходаCMOS
Schmitt TriggerNo
Technology FamilyAS
ТипBinary
VCC(Max)(V)5.5
VCC(Min)(V)4.5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)35
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN74AS869 (2)
  • Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
На английском языке: Datasheet Texas Instruments SN74AS869NT3
