Datasheet Texas Instruments TL751L12CD — Даташит
Серия | TL751L |
Модель | TL751L12CD |
Стабилизаторы напряжения с малым падением напряжения 150 мА, 26 В 8-SOIC 0–125
TL750L, TL751L Low-Dropout Voltage Regulators datasheet
PDF, 1.5 Мб, Версия: U, Файл опубликован: 28 сен 2009
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 75 |
Carrier | TUBE |
Маркировка | 51L12C |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Точность | 2 % |
Fixed Output Options | 5,10,12 В |
Iout(Max) | 0.15 A |
Iq(Typ) | 1 мА |
Noise | 500 uVrms |
Рабочий диапазон температур | от 0 до 125 C |
Output Capacitor Type | Non-Ceramic |
Output Options | Fixed Output |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable |
Thermal Resistance ОёJA | 85 В°C/W |
Vdo(Typ) | 600 мВ |
Vin(Max) | 26 В |
Vin(Min) | 6 В |
Vout(Max) | 12 В |
Vout(Min) | 5 В |
- Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL751L (11)
