Datasheet Texas Instruments SN74LVC1G80DBVRE4 — Даташит
СерияSN74LVC1G80
МодельSN74LVC1G80DBVRE4
Одиночный триггер D-типа с запуском по положительному фронту 5-SOT-23 от -40 до 125
SN74LVC1G80 Single Positive-Edge-Triggered D-Type Flip-Flop datasheet
PDF, 1.1 Мб, Версия: S, Файл опубликован: 30 ноя 2016
31 предложений от 16 поставщиков
IC FF D-TYPE SNGL 1BIT SOT23-5. Flip Flop 1 Element D-Type 1 Bit Positive Edge SC-74A, SOT-753. Logic - Flip Flops...
Эиком
SN74LVC1G80DBVRE4
от 31 ₽
SN74LVC1G80DBVRE4
от 32 ₽
SN74LVC1G80DBVRE4
37 ₽
SN74LVC1G80DBVRE4
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаC80F
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeFLIP-FLOP
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyD-Type Flip-Flop
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)9.1,6,4.2,3.8 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G80DBVRE4
