Datasheet Texas Instruments ADS8330IPWG4 — Даташит
Серия | ADS8330 |
Модель | ADS8330IPWG4 |
2,7–5,5 В, 16 бит, 1 MSPS, последовательный АЦП с мультиплексором 2 в 1, 16-TSSOP от -40 до 85
Low-Power, 16-Bit, 1-MHz, Single/Dual Unipolar Input, ADCs w/ Serial Interface datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 7 июл 2009
Pin | 16 | 16 |
Package Type | PW | PW |
Industry STD Term | TSSOP | TSSOP |
Package QTY | 90 | 90 |
Carrier | TUBE | TUBE |
Маркировка | ADS | 8330I A |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 5 | 5 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
# Input Channels | 2 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 2.7 В |
Архитектура | SAR |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 1.65 В |
INL(Max) | 1.75 +/-LSB |
Input Range(Max) | 5.5 В |
Тип входа | Differential,Single-Ended |
Integrated Features | Daisy-Chainable,Oscillator |
Interface | SPI |
Multi-Channel Configuration | Multiplexed |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Power Consumption(Typ) | 13.2 mW |
Rating | Catalog |
Reference Mode | Ext |
Разрешение | 16 Bits |
SINAD | 92 дБ |
SNR | 93 дБ |
Sample Rate (max) | 1MSPS SPS |
Sample Rate(Max) | 1 MSPS |
THD(Typ) | -102 дБ |
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8330 (10)
