Datasheet Texas Instruments TLV2361CDBVT — Даташит
СерияTLV2361
МодельTLV2361CDBVT
Одиночный высокопроизводительный низковольтный операционный усилитель 5-SOT-23 0–70
High-Performance Low-Voltage Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 27 июн 2007
Pin555
Package TypeDBVDBVDBV
Industry STD TermSOT-23SOT-23SOT-23
Package QTY250250250
CarrierSMALL T&RSMALL T&RSMALL T&R
МаркировкаYC3LYC3GYC3B
Width (мм)1.61.61.6
Length (мм)2.92.92.9
Thickness (мм)1.21.21.2
Pitch (мм).95.95.95
Max Height (мм)1.451.451.45
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)85 дБ
CMRR(Typ)60 дБ
GBW(Typ)7 МГц
Input Bias Current(Max)150000 pA
Iq per channel(Max)2.5 мА
Iq per channel(Typ)1.75 мА
Количество каналов1
Output Current(Typ)1.2 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailNo
Slew Rate(Typ)3 V/us
Total Supply Voltage(Max)5 +5V=5, +/-5V=10
Total Supply Voltage(Min)2 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)
    PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
    This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
  • Conditioning a Switch-mode Power Supply Current Signal Using TI Op Amps
    PDF, 61 Кб, Файл опубликован: 23 мар 2000
    The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp.
На английском языке: Datasheet Texas Instruments TLV2361CDBVT
