Datasheet Texas Instruments TL497ACD — Даташит
СерияTL497A
МодельTL497ACD
500 мА, пиковый повышающий, понижающий, инвертирующий импульсный стабилизатор напряжения 14-SOIC 0–70
TL497A datasheet
PDF, 777 Кб, Версия: F, Файл опубликован: 22 фев 2005
Pin14
Package TypeD
Package QTY50
МаркировкаTL497AC
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Iq(Typ)11 мА
Special FeaturesEnable
Switch Current Limit(Min)0.5 A
Switch Current Limit(Typ)0.5 A
Switching Frequency(Max)50 kHz
TopologyBoost,Buck,Flyback,Forward,Inverting,SEPIC
ТипConverter
Vin(Max)12 В
Vin(Min)4.5 В
Vout(Max)30 В
Vout(Min)-25 В
  • Designing Switching Voltage Regulators with TL497A
    PDF, 945 Кб, Файл опубликован: 11 авг 2003
    Switching voltage regulators, represented by the TL497, can achieve high-efficiency power conversion at large input/output voltage differentials. The TL497A eliminates complex circuit designs previously required and provides greater efficiency than systems using series pass regulators. The principle of operation is discussed, and practical design exercises for step-down, step-up, and inverting reg
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TL497ACD
