Datasheet Texas Instruments SN74AS175BNSR — Даташит
СерияSN74AS175B
МодельSN74AS175BNSR
Четверные шлепанцы D-типа с положительным фронтом и прозрачным 16-SO от 0 до 70
Hex/Quadruple D-Type Flip-Flops With Clear datasheet
PDF, 848 Кб, Версия: E, Файл опубликован: 23 май 2002
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
Маркировка74AS175B
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
3-State OutputNo
Bits4
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)34 мА
Output Drive (IOL/IOH)(Max)20/-2 мА
Package GroupSO
Package Size: mm2:W x L16SO: 80 mm2: 7.8 x 10.2(SO) PKG
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)10 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN74AS175B (3)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
На английском языке: Datasheet Texas Instruments SN74AS175BNSR
