Datasheet Texas Instruments UC1846J/80257 — Даташит
СерияUC1846
МодельUC1846J/80257
ШИМ-контроллер токового режима 16-CDIP от -55 до 125
UCx846/7 Current Mode PWM Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 4 янв 2016
Преобразователь DC/DC, Current Mode PWM Controller 500mA 16Pin CDIP
UC1846J/80257
726 ₽
UC1846J/80257
920 ₽
UC1846J/80257
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCurrent
Duty Cycle(Max)(%)50
Frequency(Max)(kHz)500
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
RatingMilitary
Special FeaturesError Amplifier
Soft Start
Synchronization Pin
Multi-topology
TopologyBoost
Flyback
Forward
Full-Bridge
Half-Bridge
Push-Pull
UVLO Thresholds On/Off(V)7.7/6.95
Vin(Max)(V)40
Vin(Min)(V)7
RoHSНе совместим
  • Modeling Analysis and Compensation of the Current-Mode Converter
    PDF, 189 Кб, Файл опубликован: 5 сен 1999
    As current-mode conversion increases in popularity several peculiarities associated with fixed-frequency peak-current detecting schemes have surfaced. These include instability above 50% duty cycle a tendency towards subharmonic oscillation non-ideal loop response and an increased sensitivity to noise. This application note attempts to show that the performance of any current-mode converter c
  • DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICs
    PDF, 27 Кб, Файл опубликован: 5 сен 1999
    The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806
  • U-93 A New Integrated Circuit for Current Mode Control
    PDF, 411 Кб, Файл опубликован: 5 сен 1999
    Advantages of current-mode control over conventional PWM approaches to switching power converters include automatic feed-forward automatic symmetry correction inherent current-limiting simple loop-compensation enhanced load-response and the capability for parallel operation. This application note introduces the first control integrated circuit specifically designed for this topology defines
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1846J/80257
