Datasheet Texas Instruments SN74ALVC14DGVR — Даташит
СерияSN74ALVC14
МодельSN74ALVC14DGVR
Инвертор с шестигранным триггером Шмитта 14-TVSOP от -40 до 85
SN74ALVC14 datasheet
PDF, 657 Кб, Версия: H, Файл опубликован: 1 сен 2004
35 предложений от 17 поставщиков
Интегральные микросхемы Логические микросхемы - Затворы и Инверторы
SN74ALVC14DGVR
7.25 ₽
727GS
SN74ALVC14DGVR
SN74ALVC14DGVR
ТаймЧипс
SN74ALVC14DGVRE4
Pin14
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаVA14
Width (мм)4.4
Length (мм)3.6
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits6
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTVSOP
Package Size: mm2:W x L14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) PKG
Schmitt TriggerYes
Technology FamilyALVC
VCC(Max)3.6 В
VCC(Min)2.3 В
Voltage(Nom)2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)3.7,3.9,3.4 нс
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74ALVC14DGVR
