Datasheet Texas Instruments TPS61131PWR — Даташит
| Серия | TPS61131 |
| Модель | TPS61131PWR |
Преобразователь SEPIC 3,3 В, КПД 90 % с LDO 3,3 В, 200 мА для одноэлементных литий-ионных или двухэлементных приложений 16-TSSOP от -40 до 85
TPS6113x Synchronous SEPIC and Flyback Converter With 1.1-A Switch and Integrated LDO datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 29 сен 2015
Купить TPS61131PWR на РадиоЛоцман.Цены — от 118 до 321 ₽23 предложений от 14 поставщиков Преобразователь DC/DC, Step-Up Regulator 3.3V, 90% Efficient SEPIC Converter with 3.3V, 200mA LDO for 1-Cell LiIon or Dual-Cell Applications Conv DC-DC... | |||
| TPS61131PWR Texas Instruments | 125 ₽ | ||
| TPS61131PWR Texas Instruments | от 294 ₽ | ||
| TPS61131PWR Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | PS61131 |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Approx. Price (US$) | 1.63 | 1ku |
| Duty Cycle(Max)(%) | 100 |
| Iq(Typ)(mA) | 0.04 |
| Operating Temperature Range(C) | -40 to 85 |
| Package Group | TSSOP |
| Rating | Catalog |
| Regulated Outputs(#) | 2 |
| Special Features | Enable Light Load Efficiency Load Disconnect Power Good |
| Switch Current Limit(Min)(A) | 1.1 |
| Switch Current Limit(Typ)(A) | 1.3 |
| Switching Frequency(Max)(kHz) | 600 |
| Switching Frequency(Min)(kHz) | 400 |
| Тип | Converter |
| Vin(Max)(V) | 5.5 |
| Vin(Min)(V) | 1.8 |
| Vout(Max)(V) | 3.3 |
| Vout(Min)(V) | 3.3 |
| Бессвинцовая технология (Pb Free) | Да |
- Evaluation Modules & Boards: TPS61130EVM-206
TPS61130 Evaluation Module
- Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed. - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61131 (2)
- TPS61131PW TPS61131PWR
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
