Datasheet Texas Instruments UC1825AJ883B — Даташит
СерияUC1825A
МодельUC1825AJ883B
Высокоскоростной ШИМ-контроллер 16-CDIP от -55 до 125
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаUC1825AJ/883B5962-8768102EA
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Control MethodCurrent
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Package GroupCDIP
RatingMilitary
Special FeaturesError Amplifier,Leading Edge Blanking,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)22 В
Vin(Min)8.4 В
RoHSSee ti.com
  • U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM Controllers
    PDF, 204 Кб, Файл опубликован: 5 сен 1999
    The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1825AJ883B
