Оптопары и оптореле Megawin
Datasheet Texas Instruments LM3410YSDE/NOPB — Даташит
СерияLM3410
МодельLM3410YSDE/NOPB
525 кГц/1,6 МГц, усиление постоянного тока и светодиодный драйвер SEPIC с внутренней компенсацией 6-WSON от -40 до 125
LM3410, LM3410-Q1 525-kHz and 1.6-MHz, Constant-Current Boost and SEPIC LED Driver With Internal Compensation datasheet
PDF, 1.7 Мб, Версия: H, Файл опубликован: 31 авг 2016
Pin6
Package TypeNGG
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Маркировка3410Y
Width (мм)3
Length (мм)3
Thickness (мм).8
Pitch (мм).95
Max Height (мм).8
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)1.5 A
Iq(Typ)3.4 мА
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesEnable/Shutdown,Soft Start,Thermal Shutdown
Switching Frequency(Max)525 kHz
Switching Frequency(Min)525 kHz
TopologyBoost,Sepic
ТипConverter,Inductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)24 В
Vout(Min)3 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3410XBSTOVPEV
    LM3410X Boost LED Driver Evaluation Board, 190mA, Overvoltage Protection, 4 Series LEDs
  • Evaluation Modules & Boards: LM3410XMFLEDEV
    LM3410 Boost evaluation board, 50 mA, 5 Series LEDs with SOT23 Package
  • Evaluation Modules & Boards: LM3410XSDSEPEV
    LM3410XSD SEPIC High Brightness LED Evaluation Board
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3410YSDE/NOPB
