Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LMX2571NJKR — Даташит
СерияLMX2571
МодельLMX2571NJKR
LMX2571 Синтезатор малой мощности с модуляцией FSK 36-WQFN от -40 до 85
LMX2571 Low-Power, High-Performance PLLatinum RF Synthesizer with FSK Modulation datasheet
PDF, 3.0 Мб, Версия: A, Файл опубликован: 1 июн 2016
Pin36
Package TypeNJK
Package QTY2500
МаркировкаLMX2571
1/f Noise (10 kHz offset at 1 GHz carrier)-124 dBc/Hz
Current Consumption39 мА
Integrated VCOYes
Lock Time(Typ)140 us
Normalized PLL Phase Noise-231 dBc/Hz
Output Frequency(Max)1344 МГц
Output Frequency(Min)10 МГц
Special FeaturesFSK modulation,Integer-Boundary Spurs (IBS) removal,Wideband
VCC3.15 to 5 В
VCC(Max)5 В
VCC(Min)3.15 В
VCO Phase Noise(Nom)-115 dBc/Hz
  • Evaluation Modules & Boards: LMX2571EVM
    LMX2571 Evaluation Module
  • LMX2571 Using a Programmable Input Multiplier to Minimize Integer Boundary Spurs
    PDF, 82 Кб, Файл опубликован: 12 янв 2016
    LMX2571 Using Spur-b-Gone to Minimize Integer Boundary Spurs
  • Frequency Shift Keying with LMX2571
    PDF, 267 Кб, Файл опубликован: 30 май 2017
    Frequency Shift Keying or FSK is one of the most popular modulation schemes being used in digital radio.LMX2571 is a low power PLL with integrated VCO, it can support FSK modulation through programmingor pins.This application note will focus on how to apply data to implement analog FM and pulse-shaped FSKmodulation with LMX2571 in FSK I2S mode.
Серия: LMX2571 (2)
  • Semiconductors > Clock and Timing > RF PLLs and Synthesizers
На английском языке: Datasheet Texas Instruments LMX2571NJKR
