Datasheet Texas Instruments OPA2662AU — Даташит
СерияOPA2662
МодельOPA2662AU
Широкая полоса пропускания, двойная мощность, рабочая крутизна 16-SOIC
Datasheet
TSP
Pin16
Package TypeDW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
RoHSНе совместим
  • Driving Video Output Stages with Monolithic Integrated Amps
    PDF, 69 Кб, Файл опубликован: 27 сен 2000
    Increasingly powerful computers and the rapidly expanding use of picture processing and CAD/CAM systems in almost all industry branches have combined to generate a greater and greater demand for higher resolution graphic monitors. Controlling the video output stages of these graphic monitors is a key to producing such high resolutions. Until recently, only highly complex, expensive systems have be
  • Fiber Optic Transmission
    PDF, 81 Кб, Файл опубликован: 27 сен 2000
    Fiber optic transmission is assuming an increasingly important role in systems for wide-band analog signals and digital signals with high data rates. Although the number of applications for digital networks and telecommunications systems is skyrocketing, analog transmission is still vital to many applications. Analog systems with bandwidths of up to 150MHz are used for wide-band RGB signal distrib
  • New Ultra High-Speed Circuit Techniques with Analog ICs
    PDF, 160 Кб, Файл опубликован: 27 сен 2000
    With the increasing use of current-feedback amplifiers, the Diamond Structure has come to play a key role in today's analog circuit technology. Two new macro elements that function in this structure are the Diamond Transistor and its abridged version, the Diamond Buffer. These elements can be used for both voltage and current control of analog signals up to several 100MHz. The OPA660 combines both
  • There's a World Of Line Drivers to Choose From
    PDF, 62 Кб, Файл опубликован: 2 окт 2000
    Coax cables with a typical impedance of 50О© or 75О© are used in many applications to ensure signal fidelity, and high-speed line drivers have the often difficult job of transmitting signals over these cables or over twisted pair lines. The most common way to drive coax cables is to use driver amplifiers with low-impedance voltage output, which operate with either voltage or current feed
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA2662 (1)
  • OPA2662AU
На английском языке: Datasheet Texas Instruments OPA2662AU
