Datasheet Texas Instruments CD4066BMT — Даташит
Серия | CD4066B |
Модель | CD4066BMT |
Четырехсторонний двусторонний переключатель CMOS 14-SOIC от -55 до 125
CD4066B CMOS Quad Bilateral Switch datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 13 июн 2017
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | CD4066BM |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Dual supply,Powered off protection |
Полоса частот | 40 МГц |
Bandwidth(Max) | 40 МГц |
Configuration | 1:1 SPST |
ESD Charged Device Model | 1.5 kV |
ESD HBM | 0.5 kV |
Input/Ouput Voltage(Max) | 18 В |
Input/Output Continuous Current(Max) | 10 мА |
Количество каналов | 4 |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Ron(Max) | 1300 Ohms |
Ron(Typ) | 125 Ohms |
Supply Current(Max) | 30 uA |
Supply Current(Typ) | 0.01 uA |
Supply Range | 18 Max |
VIH(Min) | vcc*.7 В |
VIL(Max) | 2 В |
Vdd(Max) | 18 В |
Vdd(Min) | 3 В |
Vss(Min) | -15 В |
- Understanding Buffered and Unbuffered CD4xxxB Series Device CharacteristicsPDF, 188 Кб, Файл опубликован: 3 дек 2001
Both buffered and unbuffered CMOS B-series gates inverters and high-current IC products are available from TI. Each product classification has application advantages in appropriate logic-system designs. Many CMOS suppliers have concentrated on promoting buffered B-series products with applications literature focusing on the attributes and use of the buffered types. This practice has left an imb - Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD4066B (16)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
