Datasheet Texas Instruments LM3633YFQR — Даташит
СерияLM3633
МодельLM3633YFQR
Комплексное решение по освещению для трубок смартфонов 20-DSBGA от -40 до 85
LM3633 Complete Lighting Power Solution for Smartphone Handsets datasheet
PDF, 1.5 Мб, Файл опубликован: 4 июн 2014
Pin20
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка633B
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Количество каналов3
Duty Cycle(Max)94 %
LED21
LED Current Per Channel30 мА
Package GroupDSBGA
Peak Efficiency90 %
Shutdown Current(Typ)1 uA
Special FeaturesAdjustable Switch Frequency,Analog Dimming,CABC,Enable/Shutdown,I2C Control,Integrated Switch,OVP,Synchronous Rectification,Thermal Shutdown
Switching Frequency(Max)1100 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)41 В
  • Evaluation Modules & Boards: LM3633EVM
    LM3633EVM Evaluation Module
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
Серия: LM3633 (2)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments LM3633YFQR
