Datasheet Texas Instruments SN74CBTS3384PW — Даташит
СерияSN74CBTS3384
МодельSN74CBTS3384PW
10-битный переключатель шины на полевом транзисторе с ограничением на диоде Шоттки 24-TSSOP от -40 до 85
SN74CBTS3384 datasheet
PDF, 874 Кб, Версия: M, Файл опубликован: 9 июл 2003
АЦП азиатских производителей
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
МаркировкаCR384
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesSchottky clamp diode to prevent undershoot
Полоса частот200 МГц
Configuration1:1 SPST
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)6.5 пФ
Количество каналов10
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)150 мкА
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Ron(Max)20 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)3 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)4 В
Vss(Max)N/A В
Vss(Min)N/A В
  • SN74CBTS3384 Bus Switches Provide Fast Connection and Ensure Isolation (Rev. A)
    PDF, 46 Кб, Версия: A, Файл опубликован: 1 авг 1996
    Buses are the pathways for communication between the CPU, memory, and I/O ports in electronic systems. The SN74CBTS3384 bus switch provides a high-speed, low-power solution to bus connections while providing a reliable solution to bus isolation. This document describes the mechanics of MOSFET switches which can lead to false switching and disruption of the bus. The SN74CBTS3384 solution to theses
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
На английском языке: Datasheet Texas Instruments SN74CBTS3384PW
