Datasheet Texas Instruments ADS42JB46IRGC25 — Даташит
СерияADS42JB46
МодельADS42JB46IRGC25
Двухканальный 14-разрядный аналого-цифровой преобразователь (АЦП) со скоростью 160 MSPS 64-VQFN от -40 до 85
ADS42JB46 Dual-Channel, 14-Bit, 160-MSPS Analog-to-Digital Converter datasheet
PDF, 3.7 Мб, Версия: B, Файл опубликован: 2 сен 2015
Pin64
Package TypeRGC
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY25
CarrierSMALL T&R
МаркировкаAZ42JB46
Width (мм)9
Length (мм)9
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
# Input Channels2
Analog Input BW900 МГц
АрхитектураPipeline
DNL(Max)0.4 +/-LSB
DNL(Typ)0.4 +/-LSB
ENOB12.2 Bits
INL(Max)0.75 +/-LSB
INL(Typ)0.75 +/-LSB
Input BufferYes
Input Range2.5 Vp-p
InterfaceJESD204B
Package GroupVQFN
Package Size: mm2:W x L64VQFN: 81 mm2: 9 x 9(VQFN) PKG
Power Consumption(Typ)1360 mW
Reference ModeInt
Разрешение14 Bits
SFDR96 дБ
SINAD75.1 дБ
SNR75.2 дБ
Sample Rate(Max)160 MSPS
  • Evaluation Modules & Boards: ADS42JB46EVM
    ADS42JB46 Dual-Channel, 14-Bit, 160-MSPS Analog-to-Digital Converter Evaluation Module
  • Correcting the Low-Frequency Response of the ADS42LBxx, ADS42JBxx for Time-Domai
    PDF, 338 Кб, Файл опубликован: 2 май 2016
    In this application report, simple schemes are described to correct the low-frequency response of ADS42LBxx, ADS42JBxx family of analog-to-digital converters (ADCs). The described schemes are useful for time-domain applications where the ADC samples a low-frequency pulse signal. These schemes are simple to implement in either analog or digital domains with minimal changes to the bill of materials
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS42JB46 (3)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADS42JB46IRGC25
