Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM5574MTX/NOPB — Даташит
СерияLM5574
МодельLM5574MTX/NOPB
Понижающий импульсный регулятор 75 В, 0,5 А 16-TSSOP от -40 до 125
LM5574/LM5574Q SIMPLE SWITCHER® 75V, 0.5A Step-Down Switching Regulator datasheet
PDF, 957 Кб, Версия: F, Файл опубликован: 4 апр 2013
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаLM5574MT
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)95 %
Iout(Max)0.5 A
Iq(Typ)1 мА
Package GroupTSSOP
Regulated Outputs1
Special FeaturesEnable,Tracking
Switching Frequency(Max)500 kHz
Switching Frequency(Min)50 kHz
ТипConverter
Vin(Max)75 В
Vin(Min)6 В
Vout(Max)70 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: LM5574EVAL
    75V, 0.5A Step-Down Switching Regulator Evaluation Module
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • Cost-Effective Transformerless Offline Supply for Light Load Applications (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications. Thedesign uses a "capacitive-dropper" front-end combined with a LM46000 SIMPLE SWITCHERВ® buckregulator from Texas Instruments. The circuit provides 3.3 V at a minimum of 100 mA from a line supply of90 VAC to 265 VAC. Theory of operation as well as design equations and performance results are given.
  • Cap Drop Offline Supply for E-Meters
    PDF, 291 Кб, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications such assmart grid E-meter applications. The design uses a "capacitive-dropper" front-end combined with aLM46000 SIMPLE SWITCHERВ® buck regulator from Texas Instruments. The circuit provides 3.3 V at aminimum of 50 mA from a line supply of 90 VAC to 265 VAC. Theory of operation as well as designequa
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Quick Start Guide for a 0.5 Amp Buck Regulator Using The LM5574 and LM25574 (Rev. B)
    PDF, 61 Кб, Версия: B, Файл опубликован: 23 апр 2013
    The LM5574 and LM25574 switching regulators feature all of the functions necessary to implement anefficient high voltage buck regulator using a minimum of external components. These easy to useregulators include either a 42V (LM25574) or a 75V (LM5574) N-Channel buck switch with an outputcurrent capability of 0.5 Amps. The operating frequency is programmable from 50kHz up to 1MHz.Protectio
Серия: LM5574 (3)
На английском языке: Datasheet Texas Instruments LM5574MTX/NOPB
