Datasheet Texas Instruments LM5575MHX — Даташит
СерияLM5575
МодельLM5575MHX
SIMPLE SWITCHERВ® 6V to 75V, 1.5A Wide Vin Step-Down Regulator 16-HTSSOP -40 to 125
LM5575/LM5575Q SIMPLE SWITCHER® 75V, 1.5A Step-Down Switching Regulator datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 4 апр 2013
61 предложений от 25 поставщиков
Microfind
LM5575MHX/NOPB
55 ₽
LM5575MHX
65 ₽
LM5575MHX
от 105 ₽
Hi-Tech Circuit Group
LM5575MHX/NOPB
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
МаркировкаMHLM5575
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Рекомендуемая замена
ReplacementLM5575MHX/NOPB
Replacement CodeS
Approx. Price (US$)2.05 | 1ku
Control ModeCurrent Mode
Duty Cycle(Max)(%)95
Iout(Max)(A)1.5
Iq(Typ)(mA)1
Operating Temperature Range(C)-40 to 125
Package GroupHTSSOP
Regulated Outputs(#)1
Special FeaturesEnable
Tracking
Switching Frequency(Max)(kHz)500
Switching Frequency(Min)(kHz)50
ТипConverter
Vin(Max)(V)75
Vin(Min)(V)6
Vout(Max)(V)70
Vout(Min)(V)1.23
RoHSНе совместим
  • Evaluation Modules & Boards: LM5575EVAL
    75V, 1.5A Step-Down Switching Regulator Evaluation Module
  • Quick Start Guide for a 1.5 Amp Buck Regulator Using the LM5575 and LM25575 (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides an easy to use process to help users design a 1.5 Amp buck regular usingthe LM5575 and LM25575 switching regulators.
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LM5575 (4)
На английском языке: Datasheet Texas Instruments LM5575MHX
