Datasheet Texas Instruments TMS320C6202GJL200 — Даташит
СерияTMS320C6202
МодельTMS320C6202GJL200
Процессор цифровых сигналов с фиксированной точкой 352-FCBGA
TMS320C6202, TMS320C6202B Fixed-Point Digital Signal Processors datasheet
PDF, 2.2 Мб, Версия: I, Файл опубликован: 3 мар 2004
Pin352352352
Package TypeGJLGJLGJL
Industry STD TermFCBGAFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка@ 1999 TITMS320C6202GJL320C6202
Width (мм)272727
Length (мм)272727
Thickness (мм)333
Pitch (мм)111
Max Height (мм)3.83.83.8
RoHSSee ti.com
  • TMS320C6000 Expansion Bus Interface to PCI Bus Through PLX PCI9080 (Rev. A)
    PDF, 257 Кб, Версия: A, Файл опубликован: 31 авг 2001
    This application report describes how to interface the Texas Instruments (TI) TMS320C6000в„ў digital signal processor (DSP) expansion bus to the peripheral component interconnect (PCI) bus using the PCI9080 bridge chip from PLX Technologies.This document contains:A block diagram of the interfaceInformation required to configure the PCI9080Timing diagrams illustratin
  • TMS320C6000 Expansion Bus Host Interface Performance
    PDF, 559 Кб, Файл опубликован: 7 фев 2000
    The expansion bus is a 32-bit wide bus that supports interfaces to PCI bridge chips, to synchronous or asynchronous external masters, to a variety of asynchronous peripherals, and to asynchronous or synchronous FIFOs. The expansion bus has two major subblocks?the I/O port and host port Interface. This application report discusses performance of the TMS320C6000? expansion bus host port. The expansi
  • TMS320C6000 Expansion Bus to Intel80960Kx/Jx Microprocessor Interface (Rev. B)
    PDF, 120 Кб, Версия: B, Файл опубликован: 31 авг 2001
    This application report describes how to interface the Texas Instruments (TI) TMS320C6000в„ў (C6000в„ў) digital signal processor (DSP) to the Intel 80960Kx/Jx microprocessor. This document contains:A block diagram of the interfaceInformation required to configure the Intel80960Timing diagrams illustrating the interface functionality
  • TMS320C6000 Expansion Bus to MPC860 Microprocessor Interface (Rev. B)
    PDF, 195 Кб, Версия: B, Файл опубликован: 31 авг 2001
    This application report describes how to interface the TMS320C6000в„ў (C6000в„ў) digital signal processor (DSP) expansion bus to the Motorola MPC860 microprocessor. This document contains:A block diagram of the interface and PAL equationsInformation required for configuring the MPC680Timing diagrams illustrating the interface functionality
  • TMS320C6000 Expansion Bus: Multiple DSP Connection Using Asynchronous (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 15 авг 2001
    You can easily interface multiple TMS320C6000в„ў (C6000в„ў) DSP devices to each other by way of a direct connection of the expansion bus (XBus). Each device's XBus I/O port masters the other's XBus host port configured for asynchronous slave mode.This application report highlights the XBus asynchronous host mode and XBus asynchronous I/O mode and explains the interface used to connect t
  • TMS320C6000 Expansion Bus to MC68360 Microprocessor Interface (Rev. A)
    PDF, 186 Кб, Версия: A, Файл опубликован: 30 сен 2001
    This application report describes how to interface the Motorola MC68360 quad integrated communications controller (QUICC) to the Expansion Bus of the Texas Instruments TMS320C6000в„ў (C60000в„ў) digital signal processor (DSP). The document contains the following elements:A block diagram of the interface and PAL equations.Information required to configure the MC68360.
  • How to Begin Development Today & Migrate Across the TMS320C6202/02B/03B/04 DSPs (Rev. D)
    PDF, 225 Кб, Версия: D, Файл опубликован: 11 ноя 2002
    Development can begin now for Texas Instruments TMS320C6202, C6202B, C6203B, and C6204 digital signal processor (DSP) systems.Because of the compatibility between TMS320C6000в„ў generation devices, existing C6000в„ў tools and development platforms can be used to develop code for the current TMS320C62xв„ў generation and other future devices. This capability allows systems to be up an
  • TMS320C6000 Expansion Bus: Multiple DSPs to i80960Kx/Jx Microproessor Interface (Rev. A)
    PDF, 557 Кб, Версия: A, Файл опубликован: 30 сен 2001
    This application note describes interface between the TMS320C6000в„ў DSPs and the i80960Jx/Kx microprocessor via the TMS320C6000 DSP expansion bus. This application report discusses the bus arbitration, the host to DSP and peer-to-peer DSP communication using the expansion bus synchronous mode.The document cointains:A block diagram of the interface, and the glue logic VHDL code<
  • TMS320C62x/C67x Power Consumption Summary (Rev. C)
    PDF, 114 Кб, Версия: C, Файл опубликован: 30 июл 2002
    This document discusses the power consumption of the Texas Instruments TMS320C6201B, TMS320C6701, TMS320C6202, TMS320C6202B, TMS320C6203, TMS320C6204, TMS320C6205, TMS320C6211, and TMS320C6711 digital signal processors (DSPs) for typical applications. The C6201B, C6701, C6202, C6211, and C6711 DSPs are manufactured on TI's advanced 0.18-micron process and operate with a core voltage of 1.8 V. The
  • TMS320C620x/TMS3206701 DMA and CPU: Data Access Performance (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 16 авг 2000
    In a real-time system, data flow is important to understand and control to achieve high performance. By analyzing the timing characteristics for accessing data and switching between data requestors, it is possible to maximize the achievable bandwidth in any system. This application note provides relevant information for TMS320C62x devices (such as the C6201(B), C6202(B), C6203, C6204, C6205, and C
  • TMS320C6000 Memory Test (Rev. A)
    PDF, 383 Кб, Версия: A, Файл опубликован: 19 фев 2002
    This set of programs has been compiled to provide a way to verify the integrity of internal DSP memory and external system memory for all devices currently in the TMS320C6000в„ў (C6000) family. Included with the memory test are all source files, the Code Composer Studio? project file, and the linker command file. The source files contain the necessary parameters to test all devices within the
  • Extended Precision Radix-4 Fast Fourier Transform Implemented on the TMS320C62x
    PDF, 177 Кб, Файл опубликован: 23 ноя 2002
    This paper discusses a method by which the Texas Instruments (TI)(tm) TMS320C62xx or C62xx high performance fixed point DSPs overcome the traditional advantage held by floating point DSPs -- precision and speed.Using the Radix-4 Fast Fourier Transform (FFT), this document illustrates how extended precision arithmetic, multiplication in particular, can be performed on the 'C62xx. Using the te
  • IS-127 Enhanced Var Rate Speech Coder:Multichannel TMS320C62x Implementation (Rev. B)
    PDF, 92 Кб, Версия: B, Файл опубликован: 4 янв 2000
    This application report provides a detailed description of the implementation of the IS-12 enhanced variable rate speech codec (EVRC) on the Texas Instrument (TI)(tm) TMS320C62x digital signal processor (DSP). Topics include program structure, code writing rules, data/program memory requirements, and performance evaluation. Issues on multichannel implementation and interrupts are also addressed.
  • MPEG-2 Video Decoder: TMS320C62x (TM) DSP Implementation
    PDF, 80 Кб, Файл опубликован: 29 фев 2000
    This application report describes the implementation of the MPEG-2 video decoder on the TMS320C62x(tm)DSP. The MPEG-2 video standard specifies the decompression and coded representation for entertainment-quality digital video, and is widely used in different digital video systems including DVB, DTV, DVD, DSS, etc. The decoder software implements all the MPEG-2 main-profile-at-main-level functional
  • G.729/A Speech Coder: Multichannel TMS320C62x Implementation (Rev. B)
    PDF, 74 Кб, Версия: B, Файл опубликован: 4 янв 2000
    This document provides a detailed description of the implementation of the G.729 speech encoder and decoder (codec) on the Texas Instruments (TI)(tm) TMS320C6201 digital signal processor (DSP). Topics include program structure, code writing rules, data/program memory requirements, and performance evaluation. Issues regarding multichannel implementation and interrupts are also addressed.Source
  • On the Implementation of MPEG-4 Motion Compensation Using the TMS320C62x
    PDF, 219 Кб, Файл опубликован: 29 июл 1999
    This application report describes the implementation of MPEG-4 motion compensation on the Texas Instruments (TI)(tm) TMS320C62x digital signal processor (DSP). MPEG-4 is a standard for coding of audiovisual information being developed by the Motion Picture Experts Group (MPEG). MPEG-4 became an International Standard in December 1998. Motion compensation is a basic component of MPEG-4 and other vi
  • GSM Enhanced Full Rate Speech Coder: Multichannel TMS320C62x Implementation (Rev. B)
    PDF, 83 Кб, Версия: B, Файл опубликован: 4 янв 2000
    This document provides a detailed description of the implementation of the GSM enhanced full rate (EFR) speech encoder and decoder (codec) on the Texas Instruments (TI)(tm)TMS320C62x digital signal processor (DSP). Topics include program structure, code writing rules, data/program memory requirement, and performance evaluation. Issues on multichannel implementation and interrupts are also addresse
  • ETSI Math Operations in C for the TMS320C62x (Rev. A)
    PDF, 51 Кб, Версия: A, Файл опубликован: 13 ноя 2000
    Many standard vocoders follow the European Telecommunications Standards Institute (ETSI) for all math operations. One of the purposes of the ETSI math functions is to standardize all math operations into a set of function calls that can be reused by many different vocoders now and in the future.The Global Systems for Mobile Communications (GSM) standard requires vocoders that follow the ETSI s
  • G.723.1 Dual Rate Speech Coder: Multichannel TMS320C62x Implementation (Rev. B)
    PDF, 116 Кб, Версия: B, Файл опубликован: 4 янв 2000
    This application report describes how the G.723.1 Dual-Rate Speech Coder has been implemented on the TMS320C62x digital signal processor (DSP). Beyond the use of the ?C62x intrinsic functions, the application report includes specific changes required to allow this coder to operate in a real-time system with other speech coders. Also reported is information on several optimization techniques used t
  • TMS320C6000 DMA Example Applications (Rev. A)
    PDF, 864 Кб, Версия: A, Файл опубликован: 10 апр 2002
    The TMS320C6000? on-chip direct memory access (DMA) controller from Texas Instruments is used to transfer data between two locations in the memory map in the background of CPU operation. Typically, the DMA is used to:Transfer blocks of data between external and internal data memoriesRestructure portions of internal data memoryContinually service a peripheralPage program s
  • TMS320C620x/C642x McBSP: UART (Rev. C)
    PDF, 293 Кб, Версия: C, Файл опубликован: 9 сен 2008
    This document describes how to use the multichannel buffered serial port (McBSP) in the Texas Instruments (TI) TMS320C6000в„ў (C6000в„ў) digital signal processors (DSP) to interface to a universal asynchronous receiver/transmitter (UART). Descriptions of the hardware configuration and software routines necessary for proper functionality are included.The McBSP is not capable of support
  • Use and Handling of Semiconductor Packages With ENIG Pad Finishes
    PDF, 129 Кб, Файл опубликован: 31 авг 2004
  • Interfacing theTMS320C6000 EMIFto a PCI Bus Using the AMCC S5933 PCI Controller (Rev. A)
    PDF, 309 Кб, Версия: A, Файл опубликован: 30 сен 2001
    This application report describes the architecture and capabilities of the AMCC S5933 PCI controller and how it can be interfaced to the TMS320C6201 digital signal processor (DSP). The DSP's host port interface (HPI) can be a PCI target, and its external memory interface (EMIF) can be used to support PCI bus mastering. Details on the signals and logic required to implement both PCI slave and maste
  • TMS320C6000 System Clock Circuit Example (Rev. A)
    PDF, 129 Кб, Версия: A, Файл опубликован: 15 авг 2001
    This document describes how to provide the Texas Instruments TMS320C6000в„ў DSP with a system clock. All of the clocks internal to the C6000в„ў are generated from a single source through the CLKIN pin. This source clock for the device is an external signal that, depending on the clock mode, either drives the on-chip Phase-Locked Loop (PLL) circuit, which multiplies the source clock in freq
  • TMS320C6000 McBSP: I2S Interface
    PDF, 93 Кб, Файл опубликован: 8 сен 1999
    This document describes how to use the multichannel buffered serial port (McBSP) in the Texas Instruments (TI)(TM) TMS320C6000 digital signal processors (DSP) to interface with devices that conform to the Inter-IC Sound (I2S) specification. I2S is a protocol for transmitting two channels of digital audio data over a single serial connection.The flexible McBSP in the TMS320C6000 supports the I
  • General Guide to Implement Logarithmic and Exponential Operations on Fixed-Point
    PDF, 50 Кб, Файл опубликован: 31 янв 2000
    Modern audio and video compression algorithms usually take the advantage of logarithmic characteristics of human ears and eyes. This approach greatly reduces the redundancy in signals being processed. However, it poses a requirement on fixed-point DSPs to handle these logarithmic and exponential operations.This application report provides a general guide to implement these operations on fixed-
  • TMS320C6000 McBSP Initialization (Rev. C)
    PDF, 232 Кб, Версия: C, Файл опубликован: 8 мар 2004
    The TMS320C6000? multichannel buffered serial port (McBSP) can operate in a variety of modes, as per application requirements. For proper operation, the serial port must be initialized in a specific order. This document describes the initialization steps necessary when either the (E)DMA or the CPU is used to service the McBSP data. Typically, the (E)DMA is used to perform read/write transfers from
  • Using a TMS320C6000 McBSP for Data Packing (Rev. A)
    PDF, 257 Кб, Версия: A, Файл опубликован: 31 окт 2001
    This application report describes how to use the multichannel buffered serial port (McBSP) in the Texas Instruments TMS320C6000в„ў digital signal processor (DSP) for data packing. Data packing involves moving either multiple successive 8-bit elements to/from the McBSP as a single 16/24/32-bit element or multiple successive 16-bit words to/from the McBSP as a single 32-bit word.The McBSP
  • TMS320C6000 McBSP: AC'97 Codec Interface (TLV320AIC27) (Rev. A)
    PDF, 289 Кб, Версия: A, Файл опубликован: 10 июл 2001
    This document describes how to use the multichannel buffered serial ports (McBSPs) in the Texas Instruments TMS320C6000в„ў digital signal processor (DSP) as a digital controller for an audio codec 1997 device.The McBSP is connected to a stereo audio codec 1997 device. This application report uses the TLV320AIC27 audio codec (AIC27) as an example. The audio codec 1997 (AC'97) standard spec
  • TMS320C6000 EMIF to External Flash Memory (Rev. A)
    PDF, 471 Кб, Версия: A, Файл опубликован: 13 фев 2002
    Interfacing external flash memory to the Texas Instruments TMS320C6000в„ў digital signal processor (DSP) is simple compared to previous generations of TI DSPs. The TMS320C6000 advanced external memory interface (EMIF) provides a glueless interface to a variety of external memory devices.This document describes the following:EMIF control registers and asynchronous interface signals<
  • TMS320C6000 EMIF to External Asynchronous SRAM Interface (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 31 авг 2001
    Interfacing external asynchronous static RAM (ASRAM) to the Texas Instruments (TIв„ў) TMS320C6000 series of digital signal processors (DSPs) is simple compared to previous generations of TI DSPs, thanks to the advanced external memory interface (EMIF). The EMIF provides a glueless interface to a variety of external memory devices.This document describes:EMIF control registers and ASR
  • TMS320C6000 McBSP: IOM-2 Interface (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 21 май 2001
    This document describes how the multi-channel buffered serial port (McBSP) in the Texas Instruments (TI) TMS320C6000? (C6000?) digital signal processor (DSP) family is used to communicate to an ISDN Oriented Modular Interface Revision 2 (IOM-2) bus-compliant device. This document also describes the usage of McBSP registers and sample code to perform the above function.
  • Circular Buffering on TMS320C6000 (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 12 сен 2000
    This application report explains how circular buffering is implemented on the TMS320C6000? devices. Circular buffering helps to implement finite impulse response (FIR) filters efficiently. Filters require delay lines or buffers of past (and current) samples. Circular addressing simplifies the manipulation of pointers in accessing the data samples.This application report addresses the following
  • TMS320C6000 C Compiler: C Implementation of Intrinsics
    PDF, 154 Кб, Файл опубликован: 7 дек 1999
    The first optimization step that you can perform on C source code for the TMS320C62xx is to use intrinsic operators. Intrinsics are used like functions and produce assembly language statements that would otherwise be inexpressible in C. The problem is that once you have performed the first optimization step, your C source code is no longer ANSI C compatible. The code proposed within this appli
  • TMS320C6000 Board Design for JTAG (Rev. C)
    PDF, 89 Кб, Версия: C, Файл опубликован: 2 апр 2002
    Designing a TMS320C6000в„ў DSP board to utilize all of the functionality of the JTAG scan path is a simple process, but a few considerations must be taken into account. The default state of the emulation signals determines whether the JTAG port is used for emulation or for boundary scan. It is therefore necessary to provide flexibility in the design to accommodate those modes that are desired.
  • TMS320C6000 EMIF-to-External SDRAM Interface (Rev. E)
    PDF, 833 Кб, Версия: E, Файл опубликован: 4 сен 2007
    Interfacing external SDRAM to the Texas Instruments TMS320C6000™ digital signal processor (DSP) is simple, compared to previous generations of TI DSPs, because of the advanced external memory interface (EMIF). The EMIF is a glueless interface to a variety of external memory devices.This application report describes the EMIF’s control registers and SDRAM signals along with SDRAM function
  • TMS320C6000 McBSP: Interface to SPI ROM (Rev. C)
    PDF, 99 Кб, Версия: C, Файл опубликован: 30 июн 2001
    The TMS320C6000? (C6000?) Multichannel Buffered Serial Port (McBSP) is designed to interface to a device that supports synchronous Serial Peripheral Interface (SPI). This document describes the hardware interface between the McBSP and a SPI ROM. The McBSP operates as the master in a user-specified clock stop (CLKSTP) mode in order to communicate with the SPI ROM. The McBSP initialization and contr
  • TMS320C6000 McBSP to Voice Band Audio Processor (VBAP) Interface (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 23 июл 2001
    This document describes how to interface the multichannel buffered serial port (McBSP) in the TMS320C6000? digital signal processor (DSP) to a voice band audio processor (VBAP). The VBAP under discussion is the TI TLV320AC56, 3V, 2.048 MHz audio processor which is a m-law companding device. The interface is also applicable to TI?s TLV320AC57, an A-law companding audio processor.The highly
  • TMS320C6000 u-Law and a-Law Companding with Software or the McBSP
    PDF, 150 Кб, Файл опубликован: 2 фев 2000
    This document describes how to perform data companding with the TMS320C6000(tm)digital signal processors(DSP). Companding refers to the compression and expansion of transfer data before and after transmission, respectively.The multichannel buffered serial port (McBSP) in the TMS320C6000 supports two companding formats: mu-Law and A-Law. Both companding formats are specified in the CCITT G.711
  • TMS320C6000 Board Design: Considerations for Debug (Rev. C)
    PDF, 96 Кб, Версия: C, Файл опубликован: 21 апр 2004
  • Using the TMS320C6000 McBSP as a High Speed Communication Port (Rev. A)
    PDF, 296 Кб, Версия: A, Файл опубликован: 31 авг 2001
    This document describes how to use the mulit-channel buffered serial ports (McBSP) in the Texas Instruments (TI) TMS320C6000в„ў digital signal processor (DSP) as a high-speed data communication port.One McBSP of one C6000в„ў DSP device can be connected to a McBSP on another C6000 DSP device to serve as a high-speed data communication port. Typically, McBSPs of similar device numbers a
  • TMS320C6000 McBSP as a TDM Highway (Rev. A)
    PDF, 313 Кб, Версия: A, Файл опубликован: 11 сен 2000
    This document describes how the multichannel buffered serial ports (McBSP) in the TMS320C6000в„ў digital signal processors (DSP) are used to communicate on a time-division multiplexed (TDM) data highway.TDM provides multiple devices a time slot to perform data transfer. Thus, multiple users operate various channels; however, each user has a set of channel(s) assigned for transmission and re
  • TMS320C6000 McBSP Interface to an ST-BUS Device (Rev. B)
    PDF, 87 Кб, Версия: B, Файл опубликован: 4 июн 2002
    This document describes how the multichannel buffered serial ports (McBSPs) in the Texas Instruments TMS320C6000в„ў digital signal processor (DSP) are used to communicate to a single-rate Serial Telecom (ST)-BUS-compliant device.The McBSP receives the framing signal, clock, and data from the ST-BUSв„ў device and processes them to generate internal frame syncs and clocks for correct data
  • TMS320C6000 Tools: Vector Table and Boot ROM Creation (Rev. D)
    PDF, 185 Кб, Версия: D, Файл опубликован: 26 апр 2004
    Texas Instruments TMS320C6000в„ў digital signal processors (DSPs) provide a variety of boot configurations that determine which actions are performed after device reset, to prepare for initialization. The boot process is determined by latching the boot configuration settings at reset.The boot process performed by the DSP is to either load code from an external read-only memory (ROM) space
  • Using IBIS Models for Timing Analysis (Rev. A)
    PDF, 301 Кб, Версия: A, Файл опубликован: 15 апр 2003
    Today?s high-speed interfaces require strict timings and accurate system design. To achieve the necessary timings for a given system, input/output buffer information specification (IBIS) models must be used. These models accurately represent the device drivers under various process conditions. Board characteristics, such as impedance, loading, length, number of nodes, etc., affect how the device d
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMS320C6202GJL200
