Datasheet Texas Instruments THS6093IPWPRG4 — Даташит
СерияTHS6093
МодельTHS6093IPWPRG4
Драйвер линии ADSL CPE, 275 мА, +12 В с отключением 14-HTSSOP от -40 до 85
200 mA +/- 12 V ADSL CPE Line Drivers datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 11 окт 2002
Чип интерфейса, 275mA, +12V ADSL CPE Line Driver with Shutdown 14-HTSSOP -40℃ to 85℃
THS6093IPWPRG4
262 ₽
THS6093IPWPRG4
264 ₽
THS6093IPWPRG4
THS6093IPWPRG4
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаHS6093I
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl100 МГц
CMRR(Min)55 дБ
CMRR(Typ)63 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)9.5 мА
Iq per channel(Typ)7.3 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Output Current(Typ)275 мА
Package GroupHTSSOP
Package Size: mm2:W x L14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)600 V/us
Total Supply Voltage(Max)14 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at Flatband(Typ)2.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)16 мВ
  • Evaluation Modules & Boards: THS6093EVM
    THS6093 Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6093IPWPRG4
