Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI UC3886DTR — Даташит
СерияUC3886
МодельUC3886DTR
Datasheet Texas Instruments UC3886DTR
Микросхема ШИМ-контроллера режима среднего тока 16-SOIC от 0 до 70
Datasheet
TSP
  • U-156 The UC3886 PWM Controller Uses Average Current Mode Control
    PDF, 794 Кб, Файл опубликован: 5 сен 1999
    The continuing development of high-performance processors is imposing stringent requirements on their respective power systems. Intel's Pentium(r)Pro power system specification, for instance, demonstrates the industry trend to operate at lower voltages and at higher currents, with tight regulation and fast transient response. The UC3886 Average Current Mode PWM Controller meets these requirements.
  • U-157 Fueling the Megaprocessor - A DC/DC Converter Design
    PDF, 678 Кб, Файл опубликован: 5 сен 1999
    This application note provides a detailed account of design tradeoffs and procedures for the development of a voltage regulator module (VRM) for the Intel Pentium (r)Pro processor. This voltage regulator features Unitrode's UC3886 Average Current Mode PWM Controller and UC3910 4-BIT DAC and Voltage Monitor ICs configured in a buck regulator. Test results and waveforms show how the VRM power supply
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UC3886 (1)
  • UC3886DTR
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3886DTR
Политика конфиденциальности
