Datasheet Texas Instruments 5962-9218301M2A — Даташит
| Серия | SN54ACT14 |
| Модель | 5962-9218301M2A |
Инверторы с шестигранным триггером Шмитта 20-LCCC от -55 до 125
SN54ACT14, SN74ACT14 datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 9 ноя 2004
Купить 5962-9218301M2A на РадиоЛоцман.Цены — от 849 до 1 874 ₽9 предложений от 9 поставщиков Микросхема Логический контроллер, Inverter Schmitt Trigger 6Element CMOS 20Pin CLLCC Tube | |||
| 5962-9218301M2A Texas Instruments | 1 714 ₽ | ||
| 5962-9218301M2A | по запросу | ||
| 5962-9218301M2A Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | FK |
| Industry STD Term | LCCC |
| JEDEC Code | S-CQCC-N |
| Package QTY | 1 |
| Carrier | TUBE |
| Width (мм) | 8.89 |
| Length (мм) | 8.89 |
| Thickness (мм) | 1.83 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Bits | 6 |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Тип выхода | CMOS |
| Package Group | LCCC |
| Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
| Rating | Military |
| Schmitt Trigger | Yes |
| Technology Family | ACT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Understanding Schmitt TriggersPDF, 80 Кб, Файл опубликован: 21 сен 2011
- Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
- TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
Серия: SN54ACT14 (6)
- 5962-9218301M2A 5962-9218301MCA 5962-9218301MDA SNJ54ACT14FK SNJ54ACT14J SNJ54ACT14W
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
59629218301M2A, 5962 9218301M2A
