Datasheet Texas Instruments TL750M05CKTPR — Даташит
СерияTL750M05
МодельTL750M05CKTPR
26 предложений от 16 поставщиков
IC REG LIN 5V 750MA 2POWERFLEX. Linear Voltage Regulator IC 1 Output 750mA 2-PowerFLEXTM. PMIC - Voltage Regulators - Linear...
TL750M05CKTPR
63 ₽
Зенер
Россия и страны ТС
TL750M05CKTPR
от 90 ₽
TL750M05CKTPR
330 ₽
Рутоника
TL750M05CKTPR
Pin2
Package TypeKTP
Industry STD TermPFM
JEDEC CodeR-PSFM-G
Маркировка750M05C
Width (мм)6.15
Length (мм)6.04
Thickness (мм)1.91
Pitch (мм)4.57
Max Height (мм)2.03
Accuracy(%)1
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.42 | 1ku
Fixed Output Options(V)5
Iout(Max)(A)0.75
Iq(Typ)(mA)5
Noise(uVrms)500
Operating Temperature Range(C)0 to 125
Output OptionsFixed Output
Package GroupDDPAK/TO-263
TO-220
TO-252
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
See datasheet (PFM)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)6
Vout(Max)(V)5
Vout(Min)(V)5
RoHSНе совместим
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TL750M05CKTPR
