Datasheet Texas Instruments TLV2462AQPWRG4 — Даташит
Серия | TLV2462A |
Модель | TLV2462AQPWRG4 |
Двойной маломощный операционный усилитель ввода/вывода с Rail-to-Rail 8-TSSOP
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
Pin | 8 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | V2462A |
Width (мм) | 4.4 |
Length (мм) | 3 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 71 дБ |
CMRR(Typ) | 85 дБ |
GBW(Typ) | 6.4 МГц |
Input Bias Current(Max) | 14000 pA |
Iq per channel(Max) | 0.65 мА |
Iq per channel(Typ) | 0.55 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 2 uV/C |
Output Current(Typ) | 80 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 1.6 V/us |
Total Supply Voltage(Max) | 6 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 11 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1.5 мВ |
- Evaluation Modules & Boards: EVMX777G-01-20-00
J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
- Using the TLV246x as a Multiplexer with Gain in a Data Acquisition SystemPDF, 62 Кб, Файл опубликован: 14 дек 1998
Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters. - TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
- Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2462A (10)
